Hi, I have a MF 165 that keeps shearing the cotter pins that goes in the little dowels on the fingers on the pressure plate. This is the second clutch I had to put in because the first one done the same thing and a piece of the clutch finger broke when this happened. I have tried different cotter pins with a strong strength including steel ones and they still shear off after tractor is used some. Has anybody had this problem and knows of a way to fix it? Could these dowel pins be spot welded to hold them in place? Thanks for any help. A photo is included showing the dowel pins I am referring too.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto9285.jpg"/>
