My MF202 is the industrial model of the MF35 so I think the 35 would have the same setup.
Anyway the spring is broken on my brake hold down. I've ordered a new one but haven't received it yet. I'm trying to figure how this thing works.
In the first pic you see the ratchet locked in with the brake on. In the second pic, you see it released. What I can't figure out is this. Does the spring hold the toe release in the upward position? This would mean that every time you stepped on the brake, it would lock in place.
With the spring in place do you have to make sure every time you use that left brake that your toe is also holding the toe ratchet down to keep it from locking?
