102 senior ???
newf
I have a tractor that the owner told me was a 102 senior but a couple of things don't look right. only has one gas tank and it has spoke rims. could he be wrong and this is a different model. haven't got pics yet because it's to darn cold to get them lol
They came with two different engines. The 244 use kerosene and the 226 use gas. you'll have to determine which engine yours has.Wheels could be from a different model.
On the top of the frame in the area near the clutch pedal there should be some stamped numbers. The top line will be the model number and the bottom is the serial.
Don't be surprised if the stamped numbers and the tag number, if there is one, don't match. Out of 5 MH tractors that I have only 2 match. You can play with these like Legos.
