aprice0101
New User
Took off the injection pump on my 23c standard diesel to fix fuel leaks. I understand that i need to match the scribe line of the letter "G" up with the cir-clips scribe line with #1 at 19 deg BTC, howeverr, when i get the engine spun there, and insert the 1/4 in rod into the flywheel through the check hole, the pump lines up slightly above "H". The pump, pump shaft and drive gear are all keyed as it can only go in 1 way.....is there something i am missing or something i can do? tractor ran before taking it off by the way. Someone please chime in, i'm relitively frustrated with it right now. Thank you.
