Ferguson 135 Multipower, split transmisson problem
I'm trying to split transmission from rear axle house. I's impossible, i have tried without too much violence. My question is, must I remove Hydralic Lift Cover first?
Perhaps anybody have a good link where I can learn how to do. I have a Workshop Manual but it's not enough Sad
I hope some have the information I need to succeed Smile
Bet you don't have the pump MP supply hose removed yet. The hose can be removed at the FRONT end after the steering gearbox is off, or the REAR after the lift cover is off. Your choice, but it has to come off one end or the other before the transmission can be removed from the differential case.
Hi, thanks for your information. I made at tool to break apart and that succeeded :D
