eurofarmer
My 50hx wil not start, batery is food an charged but there is no power at the ignition switch. No controle lights come one when you turn the
switch. The tractor does start when using an srewdriver on the starter. It does not drive, no electric to the valves. The fuses in the fuse box
located in the cab are ok. Also I did clean the conectors on the left hand front side of the cab.
I do not have a wiring schema for this tractor, does anybody know if it has some inline fuses and at what location?
Thank you
Thank you
