rmissildine
Hello all,
I have a 1965 Massey 165 diesel that I want to rewire the charging circuit, if possible.
It has the Delco 3 wire alternator, which I don't think is putting out the correct voltage/amps. Don't know, because the amp meter doesn't work. Reason being, MF put a pressure switch behind the oil pressure gauge for the amp meter and fuel gauge to run through after the engine starts, fuel gauge doesn't currently work either.
I had to replace the original ignition and went with a generic 4 position switch with ACC, Off, On, and Start.
My question is: can I bypass the pressure switch (mine is bad), and wire the amp meter and fuel gauge through the "on" terminal of the ignition switch. I have printed a copy of ptfarmer's 175 (I believe) diagram and it looks like mine.
Thanks for everyone's help.
Roger
Roger
