After running out of fuel in the middle of a field, I discovered the fuel gauge was off by 1/4 tank.
After refilling the fuel tank and the tractor not starting, I guess the problem is air in the fuel lines.
I was told there are four fuel lines and that by loosening the nut on the first one, while starting the tractor, would clear the line.
Can someone tell me where the fuel line to loosen is ?
