Agriconhyd
New User
Have a customer that bought this brand new and always had transmission issues. put a gauge on the trans pump and no oil pressure. Took the gauge off with the hose open no flow. Pulled the filter cleaned. tried again no flow. Split the tractor and the clutches look new. but the tang on the pump dive is chewed up. Bought a new oil pump and drive flange for the torque converter. Started to measure the engagement of the pump drive and it's only has .020 engagement. Not enough. Trying to figure a way of getting the torque converter closer to the trans without loosing the starter engagement. The torque needs to be moved in about .250. It's like the trans housing wasn't machine right at the factory. Anybody ever run into this?
