MF 253 Hose Part Numbers
I'm having trouble getting the right coolant hoses for my MF 253. The Agco parts books shows part number 3637574M91 as the hose that goes from the water pump to the thermostat but the hose they send you is the hose that goes from the water pump to the cylinder head (according to the parts book this is hose #747939M91). When I ordered that hose (747939M91) they sent me a pre-molded hose that looks like it is for the 263 tractor (#4223812M91). I do not believe the Agco packaging is labeled incorrectly but I believe that the part numbers in the books are incorrect. Can anyone verify this?
This is what it should be according to the online parts book.
3637574M91 is incorrect, correct P/N 747936M91 (water pump to thermostat housing).
747939M91 is incorrect, correct P/N 3637574M91 (engine block to connection pipe).
They are both straight pieces of hose.
What online book number are you looking at? I'm looking at book 819774. When I enter part number 747936M91 it does not come up with anything.
Well that clears up everything. Thanks for your help. You would think they would make a correction to the picture but maybe that's not possible.
(quoted from post at 15:39:53 01/03/18) Well that clears up everything. Thanks for your help. You would think they would make a correction to the picture but maybe that's not possible.
It's easier for them to make a note I guess, everytime I see one of those notes I always look at it just in case it applies to what I'm looking for.
