MNfarmboy83
We have a 492 with fwa on it. Using it this weekend it sounded a little noisy. I disengaged the front end and it was quiet so I finished feeding hay and carrying firewood. I got to looking after work today and saw 2 drain plugs, one on the front axel and one in the housing where the drive shaft comes into the front. I pulled the plugs and both were empty. The one on the axel was empty and clean. The one in the housing was empty and metal pieces in there that looked maybe like a metal bushing or shim got ripped apart. I just added universal fluid to see if I could find any leaks and to see if the 2 were linked together somehow as I could only find one fill plug. Sure enough both filled with the same filler plug. After filling it I did not try driving it anymore tonight to see if it made it quieter. My questions are, does anyone know what the thin metal piece are that were in the drain plug and how much damage is done? Can I just continue to use it if it continues to work? I'm thinking universal fluid is better than nothing, but do I need to drain it again and put the correct fluid it and what is the correct fluid? Sorry this is long. Thanks in advance for any help with this matter.
