Any one ever rebuild an instant reverse transmission?
I was comparing the new clutch plates with
the old ones. The old steel plates have a
definite dish but the new ones do not. Is
this going to be an issue or not?
I'd be interested in how you make out with it. My 205 wants to creep forward all the time and I have to bump the pedal to reverse to shift it. I think the plates are probably warped.
According to the service manual the originals are dished. It only mentions that the dish of the plates should all face the same direction.
By golly sir, you are RIGHT! I just checked the revers-o-matic book I have, they show to check each disc on a flat surface with the dish UP. The INSIDE clearance should be more than .005 inch, if not replace. New disc is .015-.018, also says on assembly have them all the same direction. Told you it's been a long time! LOL
Well I guess i will find out how the new plates work when the rest of the parts come in and I can get it back together. Thanks for all your thoughts on this.
Not real easy but not terrible. No worse
than splitting for a regular manual
clutch. Ideally your gonna want a nice
flat slab to do the split on. I didn't
have that so I made a track and trolley
contraption. Your also going to need to
make some guides out of some 6" bolts. Cut
the heads off and round the tip over.
Replace some of the bell housing bolts
with the guide bolts so everything stays
lined up during first four inches of the
spilt. Otherwise it will ruin the pump.
Seems like if the slightly dished plates made it apply a lot smoother, or whatever that they would be using them in cars, and trucks. Still interesting though.
Well I just finished putting the transmission back together and back on the engine. So far so good. It appears to work but I haven't load tested it yet. I still have to finish reassembling the FEL and body before further testing. It was a bit nerve racking getting the transmission lined up even with the guide rods but it eventually went together with minor adjustments and moving the flywheel.
The one wheel spinning while its in the air is the differential is working, your tractor may have another pedal to lock the differential as needed.
I know. I jacked up one wheel to see if
the transmission was engaging at all. I
was worried about the small sealing rings
on the oil supply tube of the input shaft.
They didn't go together easy.
That's why I'm glad my 1965 MF2135 industrial is a manual shuttle with a clutch. I bought a 1971 Ford 4500 TLB with the instant reverse/torque converter deal, I swapped it out for a regular Ford 6x2 manual transmission with a clutch. For what I'm going to use it for on the farm I really don't need the instant reverse/torque converter setup. The Ford instant reverse also doesn't handle/like heat too much so I'd figure I'd kill a lot birds with one stone.
I understand that. After buying most of
parts for transmission I think I could
have converted it to manual cheaper or at
least about the same price.
