Michael QLD OZ
My 745s has a Perkins L4 engine its seized and so is the injection pump, but I can see a banjo fitting high at the front of the pump where I would expect an air bleed screw, this pipe from the banjo fitting just runs down the outside edge of the pump to atmosphere.
Then down low on the pump where I imagine the oil fill gallery for the inj pump would vent is another banjo fitting that has no pipe attached. Should the two fittings be connected and if thats the case where can I buy a replacement pipe?
So I got the picture order wrong, First picture shows lower banjo fitting with pipe sheared off.
Second picture shows top banjo fitting with pipe that seems to go down to atmosphere.
Third photo is over view of complete inj pump with inspection cover removed.
Thanks in advance for any advice.
