245 distrubutor
SteveinMo
Does anyone know how to take a MF 245 distubtor shaft apart. The inside of mt distributor was a real mess. Pulled the weights and springs out and cleaned. Now I cannot seem to get it back together. Looks like they went in with the shaft out. The plate they all mount on does not want to come out. Any suggestions would be appreciated.
Worst case is there someone I could ship it to.
Any tractor parts place should have remanufactured distributors (like Yesterdays Tractor), most will require you to send in your old one as core.
A replacement is not in the budget, cost is around $300. Mine is all cleaned up just need to put it back together.
Maybe find a local automotive, or industrial electrical repair shop. A good (experienced) auto mechanic should be able to put it back together for you. I'd do it for $200 minimum ($100 if it was still all together) because its all apart, and no telling what else it may need to be right again.
