Went today to look at Mf 2500 forklift. Lift is in great shape and The 3 cylinder diesel Perkins starts and runs like a top. Hydraulics for lift mast work good as well as steering.
The problem is the transmission. When pressing either the forward or the reverse pedal the clutch pack doesn't engage until high engine rpm's are reached causing severe jerking. The problem is much worse in reverse than in forward but still even in forward it is not right. I suspect pump trouble and after reaching higher rpm the pump delivers enough pressure to shift the clutch pack but the torque converter is already somewhat locked and causes the rough shift.
Any thoughts on what might be causing the rough shifts? After it shifts it does not slip and has good power. It was about 35 deg.f this morning while I test drove but even after 15-20 minutes of operating it got no better. Oil level is full in transmission and looks clean and bright with no burnt smell. Would like to buy this unit but this transmission has me spooked. I have heard that parts are hard to get and expensive. I have tons of experience working on the old 6 and eight speed transmissions in ag tractors but have never been into one of these.
Should I run?
Thanks for any advice.
Should I run?
