Massey 1100
tim s
A friend of mine has a Massey 1100, his hydraulics has failed on the 3pt and remotes but still has steering and brakes,,I'm a John Deere guy so I don't know much about this system,,I'm thinking the stand by pressure has dropped enough to let the priority valve shut the rear components down,,if this is the reason,,how can the pressure be set up..I am thinking this model has a main pump sort of like a Deere..thanks for any help..
System is similar to JD, use a pressure gauge in a remote and see what the standby pressure is now. Will have to check the books, sticks in my mind 2300-2350 but not sure.
Yes,, and it's most likely has a priority valve some where too that has shut the hitch off..I'm thinking low stand by pressure..
