Morning Everyone,
For my loader spool replacement I wanted to have the pump specifications. The original Cessna was replaced with a Commercial P15H for which a helpful engineer at Commercial provided the specs. 3.5 gpm at 2000 psi. Although I do not have an understanding, from what I have read there is no way that would power the backhoe. I guess I am surprised that the loader moved quick enough for me to do anything.
So now I need to plan on changing the pump, filtration and the valve. Given the amount of fluid the 102 load frame hold and heat buildup, are there any suggestions about max gpm sizes?
Thank you,
Don
Thank you,
Don
