MF 2200 only going in reverse
TRHenderson
New User
I bought it thinking it needed a clutch. But told its an
automatic transmission and may just be the
linkage? Also the backhoe main barrel pumo is
leaking hydraulics
I sure hope that is all. Anybody know how hard it is to get the back hydraulics pump off the backhoe? Any good tips
<image src="http://forums.yesterdaystractors.com/photos/mvphoto6811.png"/>
My MF 2200
Nice looking machine, on the backhoe that is a rotary cylinder, not exactly easy to find parts for. If it has a external leak it may get by with changing a o-ring (may not have to take it off the machine). I haven't worked on a rotary cylinder so I'm not sure how to work on it (unless it is right infront of me then I probably could figure it out). If the transmission needs expensive repair, and if you don't need the shuttle shift you can get a MF35, or 135 parts tractor that has the same engine you have, and switch it over to a conventional transmission/pedals.
Thank you. I want to get her running to max
performance since it is in really good shape. Would
be a workhorse for sure
