Mf 175 test gauge?
On the side of the top cover or the lines coming out the front going up to the cooler? I might be wrong on this but if I remember the manual correctly I'm fairly certain the one on the side of the top cover will only give you the reading for the main 3 point pump and not the auxiliary pump. I don't recall thread size will need to look at the book, get a gauge that reads up to 5000 PSI I remember that part. What issue are you noticing with the multi-power?
The oil cooler lines coming out of the transmission, one has a tee fitting for testing MP auxiliary side pressure. If the tractor has IPTO there will also be a test plug on the PTO lever side cover.
(quoted from post at 15:03:07 11/27/17) The oil cooler lines coming out of the transmission, one has a tee fitting for testing MP auxiliary side pressure. If the tractor has IPTO there will also be a test plug on the PTO lever side cover.
I got no response from the test port to the right below the seat. 0psi. Actually junkie kind of oil in the port. It's fresh tranny oil as I rebuilt the dry brakes.
