Massey 135 power steering leak.
zoucha_26
New User
Hello all, I have a mf 135 deluxe with power steering. I previously had a leak coming from the vent on the steering box. I tore into it and the seal for the power steering cylinder was bad so I replaced. Had no leaks for around 10 hours on tractor and it started leaking again. My question is, is that the only place power steering fluid can leak into the steering box or can i get a leak in there from the steering column. Thanks
It depends on what power steering setup it has, does it have the two small cylinders out front, or does it have just the one big one that bolts to the steering box.
(quoted from post at 20:15:24 11/26/17) It depends on what power steering setup it has, does it have the two small cylinders out front, or does it have just the one big one that bolts to the steering box.
It is the single cylinder that mounts to the steering box.
On the steering column itself it will usually leak to the outside of the column. If the cylinder has a bad spot in it, it could ruin the seals you put in. The power steering setups on these are not the best in the world, all the ones (of both types) I've come across either kind of worked, or don't work at all.
