Good morning!
The air filter housing (I know a picture is worth 1000 words, but no can do) has a flat top with a center flush opening surrounded with 3/4" louvers. I have not seen anything like it in the pictures or manuals. I thought maybe an add-on, but it seems to have factory mounts.
The lower removable round section has a circular metal fixed 2"ish tube. The top of the tube is about the level of the "oil level" stamping. The tube has 4 holes 1/2" drown from its top There is about 3/4" between the sidewalls of the tube and lower section.
Trying to determine if its the correct filter assembly and how to make it functional so I can then connect it to the pipe coming from the carb.
Thank you for the help
