So I have this old 202 and have had it for a while but never got around to working on it. Ran when I parked it a few years back but had an overfull oil pan. Not sure if it is hyd oil or just the owner over filled it. One problem it also has is the loader will not stay in any position and if you let go of the control it falls to the ground.
So is the hyd pump engine driven in such a way it could over fill the engine with oil??
#2 loader falling like it does a cylinder or control problem?? Then how does one check such?? My thinking is install a ball valve or some such thing in the line and shut it off before the loader falls to see if it stops or keep going
Thanks
Also it does not have a PTO is that something that could be installed pretty easy??
Thanks
