Wondering if anyone can tell me how many were built with the continental G176 gas engine?
Having issues finding parts, thought i would try ordering from the UK, found out the gas engines were export only.
thanks
ps: cannot order from this website as I'm in Canada
Don't know exact numbers, but 65 and 165 gassers with the G176 engines are common in the states.
Hi Thomas
What parts do you need? I have a large stock of 65 parts and can get others I may not have. I am in NW Sask.
Wayne
Thanks for the replies, never thought of Sparex.
Basic engine overhaul, the power steering ram leaked, plugged the rad and overheated the engine. Need bearings, all std, Std Rings, full gasket set with seals, rebuild kit for the cessna power steering pump, kit for the powersteering ram/valve, water pump, oil pump, transmission input shaft seal, electronic ignition, and a few other items i forget right now.
I'd just push it to the back 40 and work on those other 25 tractors you have waiting to be fixed up .....
Hi Thomas
I had a look at the parts you mentioned. Looks like most parts are available.
If you are interested....reply to my personal E-mail, below right, Classic view.
Wayne
