Massey Ferguson 240 oil pressure trouble?
Have massey ferguson 240 had electronic oil
guage and switch to pressure type now datn
thing reading high? This normal stays at 30
in high range at idle.
I have seen mechanical gauges get something plugging up the line from the motor to the gauge.
When I have doubts about my oil pressure gauge I Screw a regular dial type pressure gauge directly into the motor where the sender or tube goes. That will give you an accurate reading if you have a good test gauge.
(quoted from post at 04:06:17 11/22/17) I have seen mechanical gauges get something plugging up the line from the motor to the gauge.
Good advice, I've also found the electrical type oil pressure gauges are way off in some way. The mechanical gauges are usually more accurate.
