Big D in AL
New User
I have a MF 231S and the hydraulic lift will lift fine
but when you push the lever down it will not lower
the implement unless you go and push down on it or
add a lot of extra weight on it. I feel I have the
problem narrowed down to either the lift shaft or lift
cylinder. The lift shaft on this tractor has no lube
points like your older tractors did. The guy at the MF
place said he has seen a tractor like this freeze up
here. There was water in hydraulic oil that had been
there awhile that I drained out and changed oil. Any
one have any other ideals or had this problem
before, your help and experience would be greatly
appreciated. Thank you.
