Modified low, and tucked in MF 135 diesel alternator mount.
ptfarmer
Location
San Antonio, Tx
Was out at my brothers place today, and took a couple of pictures of his low, and tucked in alternator on his 135. He did it by modifying the upper bracket that was on the tractor. This will not work if you have the 3.152 with a power steering pump.
(quoted from post at 19:35:42 11/13/16) Was out at my brothers place today, and took a couple of pictures of his low, and tucked in alternator on his 135. He did it by modifying the upper bracket that was on the tractor. This will not work if you have the 3.152 with a power steering pump.
Hi PTF
Looks like your brother used the same alternator I have fitted to my TEA20.
The mounting lugs on the alternator shown are a different layout to the alternator that was on my MF40, so it maybe easier to mount. The lugs on the alternator I have are on the centre line of the housing, which it makes long top to bottom.
I will check a bit more and order one if it looks better.
Best Regards
Burgs
