My 175 clutch
spitz
Think my clutch is taking a dive. Lost pto control and checked the clearance but it was good. The thin metal plate looks roughed up from the bottom. So my question, what all should I replace or is there anything else I should check when I am replacing the clutch? Does the clutch kit sold on this site have everything I need?
It should say in the description if the disk is included, but it depends on what clutch you need. What is the serial number on the tractor (need to know that to get the right clutch kit).
its about an inch yet. I can still shift gears and drive but it acts like a regular clutch instead of a two stage. PTO doesnt work at all. tractor engages when I lift the clutch at all.
The clutch free play is not set at the pedal, but at the clutch housing. When the bearing contacts the release lever bolts there should be 1/8 inch clearance between the rod clamp top and the housing. The one inch clearance refers to when the pedal is above the step plate. That's when the PTO should stop/start turning. This is with the pedal pin in the upper hole at the clutch housing shaft clamp.
