Doing some work with my dad on his MF65 and had to remove the power steering hoses. Low pressure side was already bad and had been clamped on with a radiator hose clamp. The high pressure seemed ok but when we removed it, some of the threads came off. It will probably come as no purpose to many of you that none of the hydraulic shops I've shown it to, have been able to fabricate a replacement due to the unusual thread pitch on the pump. I know I'm not the first one to run into this problem. Anyone out there have a solution for replacing the fittings? I've seen some other threads that referenced converter fittings but nothing that gives part numbers etc. I'd sure appreciate any suggestions or leads anyone can offer.
[/img]
[/img]
