Work Cylinder Remove
miner09
Having trouble removing the work cylinder from rock shaft.No problem with 4 bolts on top. There is two bolts that hold control levers on to cylinder. One on bottom no problem but the one behind lever I can not get to. Can't see how levers come apart to get to bolt. Tried crow foot and several different wrenches.Anyone ever remove cylinder if so how? Thanks for you help.
Manuals don't show anything about disassembly of control arms or how to remove cylinder.
(quoted from post at 12:08:10 11/12/17) I'm trying to get bolt out at top. Have piston out. Replacing cylinder with new up date one.
I know you've already got the piston out, but I figured I'd put this in here for others who search:
If using an air compressor to pop the piston out, be VERY careful. It doesn't take much pressure for that sucker to go FLYING! (ask me how I know, though I was prepared for it)
I had an issue with that bolt too, but I replaced my cylinder over two years ago and forgot how I got that bolt off. :( Sorry I can't be of more help!
