J.D.Unstyled Farm
My neighbor has a Massey Ferguson 1528 4x4 with 820 hours, the loader, power steering and 3 point lift quit working all the sudden. As it
was running, it started very suddenly to where the loader would only come up a little then would stop, the steering wheel would spin one way
on its own and the 3 point will not go up. Acted like it was low on fluid, we checked the oil and its full, but while it running you can here
the charge pump (i believe) sucking for oil and making a noise. It is a standard trans and the manual shows a screen held in by one bolt on
the driver lower side of trans, so we will clean and replace the screen with new fluid tomorrow. The Hydro pump (charge pump) is a ISEKI
GPL1-123L03 is there a screen on the suction side of the pump that could be plugged as well?? Or are these pumps known for problems? Any
helpful info would greatly be appreciated!! Thank you.
