My fix to mf65 hydraulic pump shaft hitting on steering arm
Rkh
I had the 2 shorter arms to add to steering when found out shaft was hitting on shaft. As shown in the picture, the keyway does not line up with existing arm. I ended grinding the steering arm where it was hitting(182530M1). Didnt have to grind much off. Sorry picture is upside down.
I have been wondering why you were trying to sell those arms instead of using them. Now I understand. Are they for the right diameter spindle? If they are, do you know a good machinist that could cut another keyway in the right place?
We just tried to use them the other day & found out they wouldn't work. Picked these up a yr ago from tractor place that had used tractor parts. I didnt think we needed them-thought there was clearance for the shaft.
