Should a 175 be able to lift the large round bales of around 1,800
Lbs on the three point? Mine cannot quite lift it up, am thinkng I may need to clean the filter under the seat etc.
When lowering and raising the three point, should I use the lever with the square knob or the outter lever with a round knob? Both willl lower and raise it, manual seems to say use the square knobbed lever. Thanks!
