Phil Tibbetts
Got the 65 split to rebuild the engine which spun a rod bearing. The clutch would never throw out the second stage. I just got this tractor the past summer. The clutch plates and the pressure plate all are in like new condition, must have been recently replaced. I want to get this fixed before I put the engine back in. I know the setting for the 3 adjusting bolts is supposed to be .080 to .090 and it looked ok when I removed the clutch. The heads of the 6 rivets that hold the splined center to the pto plate have been rubbing on something on the transmission side but I cannot see what it might be. Is there any other adjustments that need to be made before I reinstall the clutch assembly?
