175 pump parts
Brendon Warren
I'm trying to find the idler gear and driven pump gear for my later Massey 175. My auxiliary pump seized up and broke these gears. I also need pump too. Anyone know a good place to hunt these down?
To get the right parts this what needs to be known (per parts book).
A. (8 SPEED WITH LIVE P.T.O. AND AUXILIARY HYDRAULICS)
B. (MULTI-POWER WITH LIVE P.T.O. AND AUXILIARY HYDRAULICS) (USED REAR AXLE SERIAL NUMBER CV 19033 AND UP)
C. (MULTI-POWER WITH LIVE P.T.O. AND AUXILIARY HYDRAULICS) (USED PRIOR TO REAR AXLE SERIAL NUMBER CV 19033)
D. (8 SPEED WITH I.P.T.O. AND AUXILIARY HYDRAULICS)
E. (LATE PRODUCTION W/AUXILIARY HYDRAULICS) (SEE NOTE "A") (A) (Live P.T.O.) or (I.P.T.O.) For Side Covers And Hydraulic Tubing.
F. (MULTI-POWER WITH I.P.T.O. AND AUXILIARY HYDRAULICS) (USED REAR AXLE SERIAL NUMBER CV 19033 AND UP)
G.(MULTI-POWER WITH IPTO AND AUXILIARY HYDRAULICS) (USED PRIOR TO REAR AXLE SERIAL NUMBER CV 19033)
H. (MULTI-POWER WITH LIVE P.T.O. WITHOUT AUXILIARY HYDRAULICS)
I. (MULTI-POWER WITH IPTO WITHOUT AUXILIARY HYDRAULICS)
J. (6 SPEED WITH IPTO WITHOUT AUXILIARY HYDRAULICS) (USED REAR AXLE SERIAL NUMBER CX 5051 AND UP)
K. (6 SPEED WITH IPTO WITHOUT AUXILIARY HYDRAULICS) (USED PRIOR TO REAR AXLE SERIAL NUMBER CX 5051)
Pump p/n 526099M93M93
Idler gear p/n 515962M1
Gear pump driven p/n 515961M1
The pump i can get aftermarket. The gears i guess i can get through AGCO but theyre
pricey. Unless someone on here has another solution i will bite the bullet and order
them in the AM.
Might check some salvage yards too, most 100 and 200 series used the same parts on the auxiliary drive. I've had some shipped in from Wisconsin before, been awhile though.
