I tore my 180 down to rebuild the motor and redo the multi-power. I had the transmission reworked at the dealer so it was just a bolt it back in place deal for me. I got it running today and I cannot get it to move at all. The transmission will go into hi and all gears but will not move anywhere, it will not shift to low (I'm guessing something is stuck but looking for advice). This 180 has the two stage clutch which I also replaced. I have the plate set to .075, book calls for .080 but several people commented on other forums that .080 might be a little much (Seemed to feel better at .075 so I left it). Pumps are working because the 3 point will raise up and down. Pumps don't stop when the clutch is all the way down as the 3 point will still lift. I also adjusted the freeplay to get the 1/16th of an inch on the housing as the book states. I feel like there are probably 2 distinct issues here: 1 the hi low is stuck for some reason and 2 the clutch isn't releasing all way. Am I on the right track or do any of you have some thoughts on what this could be?
