gas engines
got a chance to get 65 that has not run in ten years .
the G176 is tired but can get a GF193 out of a 302 that went to scrap .
is it worth the or close to trying to work .
but i can not get the tractor till freeze up .
I think it could work (I never looked at doing it), you may need the flywheel, and some other parts. The throttle control, and some other small parts could be different.
i was told 196 is tired but running .
its got the fly wheel , it looks the same as my 202 .
but it been a few years since i seen it .
the front crank pulley is missing.
the manifold is broken .
got it in a engine stand getting ready for a tear down .
and hear we go .
tore down the 196 mains rods just under 3 tho .
had to look a lot to find plastic gauge .
less than 10 tho taper on the liners .
the rings had 40 tho end gap .
the valves have way to much play .
and there was couple broken vavle springs .
