1455 Tractor starts but won't move
Was out mowing and the tractor just stopped. Lights and blinkers work, if you turn key to the left, the pre heat works. If you turn to right, the lights on the dash board come on, but it won't crank. With
the key in the off position, I was able to jump it at the starter. It started right up, all the hydraulics work. If you turn the key to the "on" position, the Fuel and Temp gauges work. Put it in gear and it will
not move in either direction, and the PTO will not light up on the dash, and will not engage. Turn the key to the "Off" position, and it keeps running. This is the gear drive tractor.
