MF 175 multi-power filter question?
Camozzi04
So I'm trying to change the filter in front behind the radiator. Their is a bolt head on the bottom of the filter case that your spoused to spin counter clockwise to access the cartridge ? Am I correct. Mine seems to be froze up. Where do you get a new cartridge or filter at? I haven't seen mine yet. Apologize on the poor dialect. Thanks.
The cast filter can will sometimes be VERY tight, might need both a wrench and pipe wrench to break it loose. Does not need to be really tight when going back on. MF filter # is 191 855 M4, from your Agco dealer..
(quoted from post at 05:31:25 10/28/17) The cast filter can will sometimes be VERY tight, might need both a wrench and pipe wrench to break it loose. Does not need to be really tight when going back on. MF filter # is 191 855 M4, from your Agco dealer..
It looks like Yesterday's tractors offers that filter. I think I'll order it from them.
I was taking my 180 down to fix other items so I had the grill and hood off. With everything up there out of the way it took my 24 inch pipe wrench to get it loose. Never would have gotten it with the grill on. I assume if just gets a bit of rust to it.
