180 auxillary pump
Brendon Warren
The 180 now has mp and outlets that work. I'm now on to putting rims and tires on it. It had one very rotten rim and two rotten tires on it. I got lucky and bought a pair of rims for $125 that are new but have set around for twenty plus years and a used pair of tires for $500.
Yes. 18.4x30. I'm still lacking a pair of tubes. I'll have to do some calling around to find some today. I haven't made up my mind on putting fluid back in. I guess I'll see if it's too light in the pants.
Leave the fluid out, get some old Massey-Harris wheel weights. If I recall those will fit the wheel center you have fine. The MH weights are about 150 LB each, and are the best stacking weight you will ever see.
I've got a set of weights from some 28s. I'll have to measure them up to see if they'll fit. There is also a set of MH weights on Craigslist. I should check them out.
