Massey Ferguson 175 leaking Diesel
JzWales
New User
My 1972 MF 175 Started leaking Diesel the otherday. Spaying it from the right side of the engine?
I wonder if it's a common problem and merely needs the lines tightened up there?
Need to look closely and see where the leak is actually coming from. Might be a loose connection, line worn through, or injection pumps do spring leaks after several hours use too. Have an IH Bosch VA pump on the test bench now that came in with several leaks that needed repair..
Hi, if it is 'spraying' fuel rather than 'leaking' it the only
pressure line on the RHS of the engine (sitting in the seat) will be
the steel line from the lift pump which passes around the rear of
the engine on its way to the main fuel pump. If it's a 'pressure'
leak it is likely to be from the pipe or it could be from a loose
top on the lift pump.
DavidP, South Wales
