Not quite at that point yet but getting pretty close.
Was moving some gravel over the weekend with my 202 and the transmission let out a big BANG! Noticed that the high/low lever was not positively locking into position like it normally did. It did still move some and I had just started working. Had 20yds of gravel that had to be moved so being stubborn, I kept using it. Another large bang as I was loading the bucket and then it wouldn't move at all. The high/low lever was stuck in low and releasing the clutch would only make a light grinding noise but no tractor movement. I ended up dumping the load I had and using the backhoe to pull it back away from the pile so I could get a neighbors tractor and finish with it.
I'm guessing I bent or broke a shift fork in the transmission so once I get caught up on a few other things I'll get the backhoe off and limp (shove) it into the shop. I was eventually going to have to do some work to it anyway 'cause it would often pop out of reverse. Just terrible timing. Had me looking at newer tractors I'm ashamed to say
