ronztractor
HELLO ALL, I have a mf 35 I recently bought, I felt it had poor braking ability (could not lock up wheels).
so I removed the wheels for an inspection I found the axle seals to be leaking and shoes had oil on them.
so I removed the axles ,replaced the seals inner and outer , put new shoes and return springs on.
set up the shoe to lining adjustment and tested tractor.
braking seems a little better can lock up left wheel but the right wheel will not lock up no matter how I adjust it. Any help would be appreciated.
another question is about a device on the rt lower dash it's a switch that goes up and down it say's multi power and has a high and low marks it also say's shift to high for engine braking on it, does any one know what this is for? the linkage go to a shaft that runs into the top of the bell housing. Thanks
p.s. I would post pictures but don't know how.
