I have to remove the loader for a clutch replacement. This question maybe basic but I need an opinion before I attempt this task and see how some of you would approached it.
Method 1. After hanging the loader to an overhead beam by the arms/frame pivot point, it appears that I should be able to slide the tractor out leaving the subframe, loader arms and the bucket intact. Before I would slide the tractor all the way out, I would lift the loader so that the back of the subframe would clear the front axle. I ran this move few times in my mind and it seems like it would work… but I may not visualize potential problems.
Method 2. Another approach would be to detach the loader arms from the subframe first, slide out the tractor w/subframe and then remove the subframe. This approach would require more space and be more labor intense. It would not be my first choice.
Opinions???
Opinions???
