I would like to remove the hydraulic control valve from just under the front right side of the seat mostly due to a tripping hazard! If I can locate the cover for the valve delete, is there anything else that needs to be done to allow the three point hitch/draft to operate from the controls on the right side of the seat? I also removed what I believe is a mounting bracket for a mid-mounted mower. It was bolted onto the bottom of the clutch/flywheel housing and ran upward behind the right side radius rod just in front of the air cleaner. If any one needs this, let me know, as I have no use for it.
