Chuck NH
I just purchased a MF 35 gasoline. Seller said it was a 1960, but according to the serial number it's a 61. My question is; is the MF 35 the same as the earlier TO 35? Mine also has a deluxe decal on it, what makes it a deluxe?
It's pretty much a TO35 with some minor updates (even the 135, and the later 230 - 245 tractors use the same basic design with different sheet metal). As far as the deluxe model vs a standard model maybe few minute little differences, but I never really looked into it, to me a 35 is a 35.
john(UK)
07-09-2003 14:26:58
?Re: Re: What makes a TO 35 Deluxe a deluxe vs Std? in reply to James, UK, 07-09-2003 00:31:42 ?
Hydraulics are same on both models, just dual clutch to give live hydraulics and PTO, cushion seat and a few small differences depending on the area its in.
Hi Chuck, What others have said,and they seemed to have raised the hood a bit on the MF 35,the gas tank is more visible and the crank hole is lower. Sending pictures of a 56,58,63.
(quoted from post at 19:38:37 10/12/17) Hi Chuck, What others have said,and they seemed to have raised the hood a bit on the MF 35,the gas tank is more visible and the crank hole is lower. Sending pictures of a 56,58,63.
Just bought a MF 35. My serial # says it's a 1963. The decals on the hood say Massey Ferguson 35 Deluxe, but the front badge on the hood is Ferguson. Is this correct or has someone put the Ferguson badge on it?
Thank you for the response and pictures. Mine is just like the bottom picture, except I have the 24" rear tires and no spin out rims.
