I have a to35 project that has me stumped at the moment I had to replace the hydraulic cover because the old one was cracked badly. I am
having a problem with the replacement. The position operation rod that actuates the pump valve has a problem that I can't solve. When the
position control arm is pushed to the down position the pump control rod goes forward and slips into the detent on the bracket and then is
stuck there. Is there an adjustment that will prevent that from happening or will enable it to come out of the detent when the position
control lever is in the up positio?
Thanks
Thanks
