MF235 Fuel Tank Shut-Off Valve
Sagetown
New User
Bad O-Ring replaced this morning. Removed tank, but didn't need to do that.
In first photo U see the squished o-ring. It also has a tiny brass washer to prevent it from moving beyond the threaded stud.
No leaks now. It was leaking with valve open or closed.
To insure the valve doesn't leak, I added 1 gal of fuel to the empty tank, and let sit with valve off. Then opened it till all fuel ran out.
