massey harris pony
paulus
New User
Hello,I have a question about my MH Pony and here in Europe there is not a lot of information about it. Fact is that I'm able to buy a nr. 41 plow (hard to find here!) but there is also a side mower attached on my Pony. I want to know now if it's possible to attach both implements at the same time so they are both on the tractor?
Hope someone can help me, many thanks. :?
Simply put you would not be able to
use the plow with the mower attached.
There would not be enough clearance
under the mower once in the furrow.
(quoted from post at 05:32:00 09/23/17) Simply put you would not be able to
Hello, if that is the only problem than it's OK, I use it only for shows and not for working. :D
If the plow attaches like mine it has a long beam(?) that extends under the tractor. The drawbar is turned facing forward and the plow hooks to it. The mower doesn"t allow that.
(quoted from post at 14:31:28 09/23/17) If the plow attaches like mine it has a long beam(?) that extends under the tractor. The drawbar is turned facing forward and the plow hooks to it. The mower doesn"t allow that.
Yes, the plow has the long beam indeed. Thank you for the info!
