TractorLinks.com
Show Parts for Model:
MF135 Diesel Fuel Consumption?
fpappal
09-13-2017 18:09:43
After this last hurricane in Florida hit it got me thinking about generators. Harbor Freight has what appears to be a decent generator that runs off the PTO. Any idea how much fuel a Perkins diesel A3.152 would consume per hour running something like a generator? The specs say the generator is designed to be powered at 540 RPM.
Just a thought.
centash
09-14-2017 19:19:41
 Re: MF135 Diesel Fuel Consumption? in reply to fpappal, 09-13-2017 18:09:43
It doesn't matter much what rpm the pto or engine runs for that matter. Fuel consumption is based on load. Put that Tractor to work using all 38 hp and I will bet you will use close to 2 gallons per hour. Drive down the road with no load, you won't use half a gallon per hour. Ben
ptfarmer
09-14-2017 09:06:34
I find the Nebraska test numbers odd also.
fpappal
09-14-2017 09:03:28
Thanks for the replies. Since I have a MF135 and a MF203 I think this PTO generator is the way to go. Odd why the Nebraska test shows around 2 gallons per hour, but people seem to observe much better numbers than that.
Bob
09-14-2017 08:35:13
NO need to guess. Find out at the link below.
John Deere D
09-14-2017 07:54:48
I have a PTO GEN set on my MF FE 35X A3.152 Perkins Diesel:
Had Gen set operating last week for five hours (pubic utility was off line due to wind storm)....460 PTO RPM is 60 Cycles:
Unable to share with you the Size of the load that was on Gen Set......Engine used 1/2 gallon of Diesel / hour:
Bob....
Tony in Mass.
09-13-2017 18:55:59
My gas version of the same Perkins burns less than a US gallon an hour, more like 3 quarts- mowing at 540 PTO. So a diesel one? Less, much less than 3 quarts an hour if she's in good shape. Some stationaries use more than that.
miner09
09-13-2017 18:53:23
It would be idle or low speed so I would think it wouldn't use much. They didn't use much over a gallon per hour pulling 2 or 3 bottom breaking plow.Be cheap if you didn't have electricity.
