TractorLinks.com
Show Parts for Model:
Buggy style top for MF35 ??
bcraig2N
09-13-2017 17:51:59
Thinking about getting one of those Buggy style 3bow tops for My 1964 MF 35
Anyone got one?
What do you think about it
Does It do a good job of providing shade
Do they fold back
Did you get the 40 or 48 inch top
Did you attach to the Fender or the axle ?
Brand?
Pics would be great !
Thanks
ptfarmer
09-17-2017 20:19:56
 Re: Buggy style top for MF35 ?? in reply to bcraig2N, 09-13-2017 17:51:59
In the top picture the seat is slid all the way back to where it hits top cover, in the lower picture I slid the seat all the way forward just to show the rear bolt.
rockepg
09-17-2017 13:53:30
I have that same seat on mine too which is why i ask. Looks like you are even using the same holes. Do you find it feels like you are to far forward? Feels like i have to almost reach back to use the pedals and have to use the pads in front of the pedals for foot rests.
ptfarmer
09-17-2017 10:14:07
Get my seats from tractor supply, didn't drill no new hole(s), and did not shorten the base, a complete bolt on (this one is on my MF2135).
The front bolt.
The rear bolt.
rockepg
09-17-2017 07:29:12
Did you end up shortening the base on that seat so you could move it back further?
ptfarmer
09-16-2017 17:04:34
bcraig2N
09-15-2017 23:23:26
:lol: :lol: :lol:
ptfarmer
09-15-2017 21:49:59
Here you go
rockepg
09-15-2017 20:29:21
Friend of mine down the road actually has a picnic table umbrella attached to his. I give him a hard time since it kind of looks like a mary poppins thing. :)
bcraig2N
09-15-2017 15:19:56
They are not perfect by any means but not bad
The more I think about it the more it makes sense for me to just use a heavy duty umbrella attached to the back of the seat that I can remove when I want to .
Now to find a heavy duty umbrell that is reasonable priced !
ptfarmer
09-14-2017 23:39:10
If your tractor has fenders that aren't beat up I wouldn't mount anything on them, once you do they are ruined.
D beatty
09-14-2017 22:58:49
Try Heritage Farm Power they have a online web site. They have the buggy style top and have it in fender mount or axle mount.
ptfarmer
09-14-2017 22:18:02
I mounted it to the fenders since it was rush job so I wouldn't get cooked. If I would have had the time I would have also mounted it to the axle housings. I used three bolts per side, and I've had to reweld the upper mounting tab on the left hand side twice that uses a single bolt (it uses two bolts per side where it bolts lower down on the fenders). So its holding up pretty good for a rush job. Once the weather cools down, and I have the time I'm going to make it look better, and add on some extra mounts so it will bolt to the axle housings also. I'll get a picture, or two of the mounting points this Saturday, and post them.
bcraig2N
09-14-2017 20:29:10
Looks good
Did you attach to the axles ?
When you get the time would you mind posting close up pics of you attachments?
Thanks
Hay hay hay
09-14-2017 12:01:24
Yes I had one on a MF50, and have the ripped out holes in the fenders to prove it. Don't leave it out in the wind. Combination of vibration and wind....not good. Metal fatigue.
D beatty
09-14-2017 21:12:17
 Re: Buggy style top for MF35 ?? in reply to Hay hay hay, 09-14-2017 12:01:24
When you mount on fenders use large diameter flat washers under bolt heads and you won't have that problem.
ptfarmer
09-14-2017 09:11:52
There is a used 5 bow on ebay (looks like the fabric is torn) starting bid is $200.00 no bids on it yet. The 5 bows seem to be a rare bird these days, but with all the newer tractor having rops on them you can't use the buggy type. Even the 3 bows new on ebay (with a selection of different color canopies) are kind of expensive for what they are.
ptfarmer
09-13-2017 22:44:40
I made this out of some tubing, and a old golf cart top. If you have the ability its worth doing, I probably have about $15.00 in it.
wjytexas
09-14-2017 05:28:27
 Re: Buggy style top for MF35 ?? in reply to ptfarmer, 09-13-2017 22:44:40
Tractor Supply has them but they are only in yellow.
bcraig2N
09-13-2017 21:46:58
Well I tried several different searches and it appears that everyone is out of stock
Just as well I suppose as the price on the 3 bows are already fairly high.
Seeing as How my use will be to just keep sun off of me while I am Bush hogging in Low 3rd or Low 4th I may just find me a heavier duty than normal umbrella and affix it to the back of the seat .
bcraig2N
09-13-2017 20:49:32
Ok ,I will try to google a 5 Bow and see what it looks like.
ptfarmer
09-13-2017 20:32:23
My brother had a 3 bow buggy top, and it lasted a long time, but the 5 bow would handle more abuse than the 3 bow. We had to repair the 3 bow a couple of times before it finally came off, vibrating/shaking fenders does the most damage.
Since yesterdays tractor sells parts the forum will block links to other known parts sites.
bcraig2N
09-13-2017 19:01:37
I haven,t seen a 5 Bow,what brand? do you have a link?
Thanks
miner09
09-13-2017 18:55:42
They are good. Get the 5 bow top. Think they are 48 inches. It will fold back. Mounts on the fender.
